Mick
Hi Dylan,
I have installed this modification but it seems the categories are broken.
What happens is that if you add a category the default one disappears, if you edit the default category then it disappears, any kind of edit or add a new one and nothing shows up at all.
Even if you select who can view and who can submit it will still disappear completely.
So with this in mind you can only have one category which is the default category, but you cannot edit it at all or it disappears.
I will try an earlier version because this is unusable this way.
Thank you very much for your time.
Mick
This is not an issue I've been able to replicate. I can successfully create new categories, and modify existing ones.
If there's anything in particular you're changing then please provide that information. Otherwise, please check the database to see if the categories are still present there.
Legacy vBQuiz
