Question Can't get Smiley To Work With VBShop
highlander
I can't seem to add smileys through the shop. Every time, I get this error:
"There was an error encountered with your upload:
Invalid URL"
If I upload the file, it is not visible in smiley manager - graphic doesn't show up.
Do you know what would cause this?
Also, is there a way to limit where people are getting smileys from? I'm just a little concerned with malware.
Make sure the image server you're attempting to use correctly sends the image headers - if vBShop can't detect that the URL is an image, it will fail.
Hello highlander,
Legacy vBShop
