San
They have not been working for some time. I have tried to disable and then re enable them, with out any luck.
I'm able to reproduce an issue where only the first click of the Reload link will work. All subsequent automatic or manual refreshes will fail.
Is that consistent with the behaviour you're experiencing?
Update: I've released a hotfix that should address the issue described in my previous post.
I'm unable to replicate any issues with AJAX Threads (beyond the above) on your site - I still see all AJAX requests to fetch new posts go off as intended.
That being said, the file: /dbtech/vbslider/clientscript/jquery.mobile.customized.min.js?v=300b1 on your server has a JS error. This is due to an issue with our server-side JS minifier over-minifying that file.
I've corrected that issue as well.
Re-downloading and re-uploading AJAX Threads and vBSlider should fix these issues for you :)
Im still not getting ether one of them to run, do you think I should uninstall then reinstall them both ?
The errors are gone now and the manual and automatic reload are all working fine for me.
Try clearing your browser's cache, maybe?
Legacy AJAX Threads
