seventhaxis
I posted over on the vbulletin.org forums but figured it might be more beneficial to get help from the source. Currently considering purchasing the Pro version to this and other products, but I'm trying a few out (or will be soon) first. My only issue so far with the Arcade is that it's not saving scores. Initially I thought this was due to the setting "Local Scoring Unsupported" but even with that changed to "Higher is Better/Decimals" we're still not getting anything saved.
All games currently are either imported or downloaded from Mochi. I don't see anything about a Mochi ID in the configuration (and I don't have one yet to put in even if I did), and I am confused whether or not the .htaccess changes would apply to me here. In any case, any support and help is greatly appreciated. I really like this arcade over other options and want to make sure things work properly before I upgrade.
Thanks!
Just to confirm, you are running the Apache web server and you have performed the .htaccess changes, correct?
Legacy vBArcade
