Jonty
Hi there,
I've purchased vBShout, and i'm keen to install it on my forums.
The trouble is, the forums are load balanced EC2 instances, i.e. multiple file systems.
This is fine for most of your plugins, as most dont write to the file system, but this one appears to.
The problem is with the AOP directory which is require to be set to write files to - what appear to be just timestamps in text files.
I found this thread, but I noticed in the code when I had a look, it mentioned database?
Does this mean the file system requirement has changed? Or will I need to modify the files still.
Thanks
if (!is_writable(DIR . '/dbtech/vbshout/aop/'))
// Fall back to database
self::$fetched['error'] = $vbphrase['dbtech_vbshout_aop_error'];
// Time now
$mtime = TIMENOW;
Thanks
