Bug 4.2 Unable to save settings
Johnsy
I am unable to save any settings in the default instance. For example set the shoutbox to be above the footer.
Fresh installation of 4.2 and shoutbox.
Hope someone can help!
Are you getting the message about PHP 5.3.9 or newer and max_input_vars?
yep, Just added to this to my .htaccess file
#deny from all
#allow from 185.24.99.51
<IfModule mod_php5.c>
php_value max_input_vars 10000
</IfModule>
<IfModule mod_deflate.c>
AddOutPutFilterByType DEFLATE text/html text/plain text/xml text/css text/javascript application/x-javascript application/javascript
<IfModule mod_setenvif.c>
# Netscape 4.x has some problems...
BrowserMatch ^Mozilla/4 gzip-only-text/html
# Netscape 4.06-4.08 have some more problems
BrowserMatch ^Mozilla/4\.0[678] no-gzip
# MSIE masquerades as Netscape, but it is fine
# BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
# NOTE: Due to a bug in mod_setenvif up to Apache 2.0.48
# the above regex won't work. You can use the following
# workaround to get the desired effect:
BrowserMatch \bMSI[E] !no-gzip !gzip-only-text/html
# Don't compress images
SetEnvIfNoCase Request_URI .(?:gif|jpe?g|png)$ no-gzip dont-vary
</IfModule>
<IfModule mod_headers.c>
# Make sure proxies don't deliver the wrong content
Header append Vary User-Agent env=!dont-vary
</IfModule>
</IfModule>
Hello @Johnsy,
We hope your ticket regarding vBShout has been addressed to your satisfaction. This ticket has now been closed.
