Hey all,
We're releasing DragonByte Shop v4.0.0 Beta 2 for XenForo in order to implement changes requested by the community, resolve issues reported by the community, as well as make the modification more developer-friendly.
If you like the product you can show your support by reviewing it here: [DBTech] DragonByte Shop | xenForo Community.
Complete Change Log
New Features:
Changed Features:
Bug Fixes:
As always, thank you for your continued support
Discuss this news here.
Complete Change Log
New Features:
- If the "Usergroup Change" item uses additional usergroups, as opposed to changing the Primary Usergroup, this is now undone upon item deactivation
- Points are now displayed in the postbit
- Purchased items are now displayed in the postbit
- Items that come pre-configured now extend their duration when a member buys a new item of the same configuration
- You can now create Trophies using "User has purchased at least X items" as a criteria
- You can now create Trophies using "User has purchased item X" as a criteria
- You can now create Trophies using "User has purchased an item of item type X" as a criteria
- You can now define an optional "Configuration Notification Sender" that will be used as the sender when sending PMs about items being configured. We recommend setting this to a "Forum Bot" user that is used for notifications only, in order to ensure PM delivery.
- You can now define an optional "Purchase Notification Sender" that will be used as the sender when sending PMs about items being configured. We recommend setting this to a "Forum Bot" user that is used for notifications only, in order to ensure PM delivery.
- All AdminCP pages now have breadcrumbs for easier browsing
- All Front-End pages now have breadcrumbs for easier browsing
- (Developers) All DBTech_Shop_DataManager_X classes can now be extended via the XFCP system
- (Developers) All DBTech_Shop_Item_X classes can now be extended via the XFCP system. This allows you to write add-ons that run on every event pertaining to item (pre-purchase, post-purchase, configure, sellback, discard, gift)
- (Developers) All DBTech_Shop_Action_X classes can now be extended via the XFCP system.
Changed Features:
- The inventory no longer displays the shop list. All items are now shown, but grouped under their respective categories from all shops
- The various "Style" item types now only accept A-Z, a-z, 0-9. rgb() values are no longer accepted. This is a security measure to prevent malicious use of these items.
- The AdminCP management areas are now tabbed for easier editing
Bug Fixes:
- In certain instances, the AdminCP could fail to load with this mod enabled
- A caching error caused phrases to not be cached as intended in the AdminCP, causing increased query count on DB Shop pages
- The "Enable Navtab" option would not work as intended
- Mass updating currencies would display an error
- In certain scenarios, the wrong action files could be loaded
- The "Rounding" (precision) setting was hidden from the Currency Manager
- Currency rounding was not being properly applied to currency displays
- Deleting the default shop then re-adding it would not work as intended
- Multiple shop tabs would not correctly reload the page in the Shop
- Multiple shop tabs would not correctly reload the page in the Inventory
- In certain scenarios, items with a price > 0 could fail to purchase
- The "Purchase Notifications" and "Configure Notifications" would cause an error if the current user and notification recipient was the same
- Purchasing multiple copies of the same item would not display the multiple copies correctly in the inventory
- An empty inventory would generate entries in the server error log
- Deleting an item could generate entries in the server error log in certain scenarios
- Setting the shop owner would cause a PHP Fatal Error
- In certain scenarios it would not be possible to complete checkout
- Deleting items could produce a PHP error
- Purchasing an item with limited stock could produce an error from the Shop Inventory datawriter
- Having a Shop Owner could produce a PHP error on the shop list
- Creating an item with a duration > 0 could produce a PHP error on checkout
- Deleting an item in the AdminCP will now also remove it from users’ shopping carts
