Vicc67
Hi !
11 Beta - best product, however, there are some nuances.
1. Conditions Manager - not order values
2. Manage Option - still not editable title
3. not comment on someone else's Item
4. not parsed Youtube link in to Description and Note
5. Random Order Options / Specifications
6. design ?
7. old 1.0.9 problem. Not buy now
8. not possible to create text field in Specification -> Category
9. design: h1 for Items Title
1 Is fixed for Beta 12, but 2 should be working, it is on my dev version. The same is true of 7. I've posted a question about another user with this number 7 bug in this post: http://www.dragonbyte-tech.com/f236/buy-now-url-error-12784-post71875/#post71875.
Can you see if that applies to your server?
Thanks for the bug reports and suggestions, I'll get on with implementing them or fixing them asap.
PS, if possible in the future can you separate each issue or request into separate threads... I'll lose track otherwise... :D
ок, just quite a few them :)
Don't worry, we can cope with that... :D
I've uploaded a fix for the MySQL error and also for the error in trying to delete an option in the AdminCP. From tests others have done the fixes for the edit of the title in Options and also the delete of Specifications already works in Beta 11. Does your serve cache files in any way? If so flushing the cache might be a solution to these issues. If not, can you take me the steps that cause the error? :)
Thanks for your input matey. :)
4 is sorted in Beta 14.
6 is fixed by allowing the admin to use a StyleVar to specify the height of the sub gallery.
For my reference... these are still to be sorted:
Though I would really like you to explain what you mean by number 9... :D
I can not be certain what Vicc67 meant but I think it refers to the Edit Pencil image which I believe was sorted. It displayed regardless of the usergroup permissions. Therefore if someone doesn't have permission to edit they do not need to see the pencil but like I said it was sorted.
...but perhaps it's something else? :cool:
I've now got working in v2 the ability to comment on listings directly on the listing view page.
Legacy DragonByte Classifieds
