Bug Vbulletin wall formatting and bugs
Website
http://www.germanboost.com
Product version
1.2.3
Forum version
vBulletin 4.2.x
#1
Posted on the VB.org forums but was told to post here. Anyway, I'm having a few problems.
Having this problem where if a post comes in live instead of using ' ' marks it displays the whole quote box. If I refresh it's fine:
Another issue, seems to have trouble with url's in quotes:
Also my links are not blue so they blend into the text, need to know what stylevar to change.
Belazor
Staff member
Owner
Developer
Can you please show a screenshot of how it looks after refresh? From what I can tell, the quote box AND the " " are both being shown on that screenshot - exactly as designed.
There's nothing I can do about that, it's the way vBulletin handles long strings. You can produce this bug all over vBulletin in certain instances, and it's also why they break up strings after approx. 200 characters if no space is found in it already.
sidebar_content_link_color / sidebar_content_link_hover_color
Also, embedded videos don't show on the feed.
I'm unable to replicate this.
#4
You can see it there in the picture, one post has the quote bubble and the other has quotation marks. After refresh, all have the quotation marks instead of the default VB quote block.
Understood.
Thanks, got it. What about on the main feed page not the sidebar? Can't seem to figure out how to do it or change the font.
Have this issue not on the sidebar but the main forum feed page. Shows youtube link instead of embedded youtube video.
Belazor
Staff member
Owner
Developer
I'm unable to replicate this issue here on DBTech, can you please double check?
That's link_color I believe.
I'm also unable to replicate this issue, it even works fine within a quote tag and correctly shows the full-size video (rather than the tiny preview in the sidebar).
You may want to check that you have enabled the VIDEO tag in non-forum areas, via the vBulletin Options.
Baal
I am having this issue also, some the quote bubble shows and others it doesnt.
Belazor
Staff member
Owner
Developer
If the ending [/quote] tag appears later than the preview cut-off, it cannot be displayed. This is not a bug, and is not something I can "fix" short of disabling and removing all BBCode from the previews.
Forum Live Feed & User Wall
