Known Issues
- Disabling System Messages in the Shoutbox Settings also hides them from the System Messages tab.
- Disabling Notifications in the Shoutbox Settings also hides them from the Notifications tab.
- There's no setting for the Active Users block location / disable in the Shoutbox Settings.
F.A.Q.
Q: Can you move the Active Users block?
A: The idea is that both users and Administrators should be able to configure location (or hide it altogether). See known issue above.
Q: Where's the link to the Shoutbox Settings / Archive / Detach?
A: They're moved to the drop-down menu you get when you click the shoutbox' title. This was done to support the new compressed layout and still have it look good on 800x600.
If you want the buttons back, you can edit the dbtech_vbshout_editortools_pro template.
Q: Why doesn't the Smiley button show a small window with the same smilies the Posting interface does, with a "More" link?
A: Most commonly, the smilies shown at first are ones we normally type, like : ) etc. Having a button makes it easier to get a complete overview of the smilies the users may not instantly know the short-cut for.
Hope that answers some of your questions
Do keep in mind that some features discussed in this thread may be exclusive to the Professional version.
