Question VBshop and VBcredits cross compatability
Website
http://www.fractured-gaming.com
Product version
3.3.1
Forum version
vBulletin 4.2.x
#1
I was wondering before purchasing if the credits from VBcredits are compatible with VBshop.
For instance, Users donate to get points or get login rewards, can they use the same credits with VBshop, or are the different values?
Belazor
Staff member
Owner
Developer
Hi there,
You can use the same currency in both modifications by simply configuring vBShop to use the same points table and points field as vBCredits :)
By default, vBCredits uses user for the Points Table and credits for the Points Field, that is what you would fill out in vBShop :)
#3
thank you for the confirmation... can it also work the other way? instead of VB credits to VB Store, can it go VB Store to VB Credits?
Belazor
Staff member
Owner
Developer
Sure :)
You'll want vBCredits to control the points accumulation, e.g. you'll want to turn off the Points for Post and Points for Threads that vBShop comes with.
vBCredits has a lot more ways of letting you earn points, so it's much better suited for that task.
Company Information
Staff member
Company Info
#5
Hello Mokey,
vBShop
