Bug vBSecurity issue
Website
https://mdshooters.com
Product version
2.2.4
Forum version
vBulletin 3.8.x
#1
Hello
downloaded the demo to allow my mod to test this. once installed the admin options show in the left sidebar but upon clicking each one they all have a blank white screen? Any ideas, will likely purchase but want to make sure this is what he wants.
THX
Kevin
FYI- I did uninstall and reinstall, also overwrote it once.
Belazor
Staff member
Owner
Developer
Hi there,
Can you please make sure that display_errors is turned on in php.ini and that config.php does not have define('SKIP_ALL_ERRORS', true); enabled?
If I cannot see the error message because it is masked by the server, I cannot assist you :(
#3
Hi there,
will do, not much my thing, will have web guy do it, Sorry i did have the plugin disabled while I tried something. it is enabled now again
Will report back when he checks that out
THX
#4
fyi while waiting for him to fix what you asked
when in the admin area and i click a tab to see settings in the vb security control panel this error comes up
GET Log in - Maryland Shooters - vBulletin Admin Control Panel 500 (Internal Server Error)
THX
Belazor
Staff member
Owner
Developer
You'll need to inspect your server error log for the real reason behind a 500 Internal Server Error :)
Company Information
Staff member
Company Info
#6
Hello puritanize,
vBSecurity
