Hi
In the vbulletin admin backend under VbAnswers >> Forum Manager I see all the forums listed with points assigned to solution, best answer and good answer. Can you please explain where exactly these points are used? For example: for deciding the trophy winner for 'most solution' does vbAnswer consider the total number of solutions or does it consider the total number of solution points?
Thanks
Thanks
