The problem occurs when....
I already have one Select Field type of Custom Field set up,
then I set up a 2nd Select Field.
The 2nd one will include the all select field options from both the 1st instance and the 2nd when creating or editing a review.
When in the Admin panel and Custom Fields setup, they both appear with the correct fields.
(The only way you can see this is with Admin access if you can't duplicate it on your system.)
Joe
Joe
