Question Top stats template
Website
http://www.thelove4um.com/
Forum version
vBulletin 4.2.x
#1
We need to adjust how the top "x" "stats" are laid out. Which template do we do this in? Some rows need to be bigger, some smaller. Thanks.
Ozzy47
Former Developer
#2
Is this installed on the site you provided in the issue above? I am seeing nothing pertaining to the mod on that site.
#3
What are you not seeing? I just double checked, the mod is enabled and turned on. Earlier I turned off some other mods because the thread rating mod was not working correctly, but this mod was left on.
Add 4um/forum.php to the URL to see the forum.
Ozzy47
Former Developer
#4
It's gonna depend on what stats you are showing and will allowed to be changed. Most of it can be done in the templates that start off dbtech_infopanels_block_
Belazor
Staff member
Owner
Developer
#6
The templates are named as Ozzy said, so you can change the layout from there.
Note that we won't be able to assist with customisations of this nature, as we can only support the default layout :)
InfoPanels
