Question Special Characters Filter
neogeo
I'm using DragonByte SEO 2.0.42 in an old spanish VB 4.2.5 forum
I can't convert the special characters to normal ( 'á' -> 'a') or ('ö'->'o' )
Could you help me to solve it please?
I have this on DragonByteSEO:
All my VB databases tables are: latin1_spanish_ci collation
Do you why what I'm doing wrong?
Thank your for your help
Ah, I just realised you're using the Pro version.
Can you please re-post this thread with the account that purchased a license for this product?
Where I could found the license number? I bought this VB forum to another guy in March ¿is in the control panel of this addon?
Ah, I see. There is a valid license for that domain so we'll just go with that :)
If you're trying to replace UTF-8 URLs with latin ones, you should not use UTF-8 URLs as I believe the filter is ignored in that case.
Turn off UTF-8 as you are not using it.
Hi! you was right! I turned off the first option and now the speacial characters works correctly on the url! :)
Thank you Fillip!
But I have a doubt, about the second option, I tested with ON and OFF, and works well both cases, so I want to ask you, which option I have to select ¿on or off? (maybe if first option is off then the below option is disable so dosnt matter?)
A)
B)
Hello @formentera,
We hope your ticket regarding DragonByte SEO has been addressed to your satisfaction. This ticket has now been scheduled to be closed.
Hello @formentera,
As we have not heard back from you, your ticket regarding DragonByte SEO has now been closed.
