Nirjonadda
Hello
Sidebar Blocks Not Working.How I can Add Block create vBDonate for sidebar? please need tips and php code for display on side bar.
First go to ACP / DBTech - vBDonate / vBDonate Dashboard / General Settings and make sure the option Enable Forum Sideblock? is set to yes.
Then go to Forums & Moderators / Forum Blocks Manager click on Add Block.
On the next page in the dropdown choose DBTech - vBDonate and click on Continue.
On the next screen set up the options how you wish, Maximum Results is how many entries will show on the block. Latest X Donations is for the Latest Donations, Highest X Donators is for users that donated it adds all their donatons together on the entry in the block.
The only setting in there that does not matter is the Title as I have that set with a phrase, it does not use the title on the block header.
Its is fixed but Show A Donate Block In The Postbit? I want the block in another location how i can do it ? please need tips for display on Below on Rep Power.
It is all spelled out in the setting, Automaticly Deploy In Postbit?
If you want the block in another location than the default set this to "No"
and insert the following code somewhere in the postbit_legacy template.
{vb:raw template_hook.postbit_vbdonate_message}
If you want it like in the following image add that code into the postbit legacy template at the following location:
It the postbit_legacy template find
<span class="usertitle">
And add {vb:raw template_hook.postbit_vbdonate_message} directly above that.
Ok try this, in that same template add the code right above {vb:raw template_hook.postbit_userinfo_right} and see if that does it.
pm me a admin account and I will look into it for you, and what style you wish this done on.
but one problem i cannot Disable vBSecurity for access in admin panel.vBSecurity Administrator second password not working when Enable/Disable Product.
Details Here: http://www.dragonbyte-tech.com/f121/all-activity-clean-up-7639/
please try to add option Postbit: Display Location !
example: Where do you want Donate showcase to appear in postbit?
1.userinfo_right (legacy postbit)
2.userinfo_right_after_posts (horizontal postbit)
3.userinfo_left
4.signature_start
5.signature_end
6.No display
I hope it's helpful !!!
Nirjonadda Ok in the next version it will have more options to auto display in the postbit templates, I gave all of them even though IMO some of them are not needed, but some users may like it.
Here is how the options will look now:
The new version should be out on Friday June 15th if all goes to plan. It would be a normal upgrade at that time, add all the files to the server and import the product xml. ;)
I want to ask one question about that vBActivity & Awards ! Have a option Postbit: Display Location ! example: Where do you want Awards showcase to appear in postbit?
3.userinfo_left
4.signature_start
5.signature_end
6.No display
Have a option hide VBactivity bars on Postbit?
please confirm me Than I can buy This Product !!!
Screenshots Needed please !
While playing with the different locations I also now added a new location, in the postbit controls, for admins that want the postbit stuff less in your face. (IMO that looks the best)
Have a this options on running version vBDonate v1.1.1 ? How to upgrade only import XML file does it work ?
Legacy vBDonate
