Bug receiving errors after install in forum blocks manager
OUTL4W
After pro install of DBseo receiving fatal error's when creating a forum block in ACP>Forums & Moderators>forum blocks manager that pertain to anything dbtech
HTML:
Invalid block type name on line 858 in /home/dmshadow/public_html/includes/class_block.php
#0 /home/dmshadow/public_html/admincp/block.php(162): vB_BlockManager->loadBlockTypeClassByName('dbtech_status')
#1 {main}
Fatal error: Invalid block type name on line 858 in [path]/includes/class_block.php in [path]/vb/vb.php on line 286
#0 vb_error_handler(256, Invalid block type name on line 858 in /home/dmshadow/public_html/includes/class_block.php , /home/dmshadow/public_html/vb/vb.php, 286, Array ([exception] => Exception Object ([] => Invalid block type name,[] => ,[] => 0,[] => /home/dmshadow/public_html/includes/class_block.php,[] => 858,[] => Array ([0] => Array ([file] => /home/dmshadow/public_html/admincp/block.php,[line] => 162,[function] => loadBlockTypeClassByName,[class] => vB_BlockManager,[type] => ->,[args] => Array ([0] => dbtech_status)))),[code] => 256)) called at [(null):0] #1 trigger_error(Invalid block type name on line 858 in /home/dmshadow/public_html/includes/class_block.php , 256) called at [/home/dmshadow/public_html/vb/vb.php:286] #2 vB::handleException(Exception Object ([] => Invalid block type name,[] => ,[] => 0,[] => /home/dmshadow/public_html/includes/class_block.php,[] => 858,[] => Array ([0] => Array ([file] => /home/dmshadow/public_html/admincp/block.php,[line] => 162,[function] => loadBlockTypeClassByName,[class] => vB_BlockManager,[type] => ->,[args] => Array ([0] => dbtech_status))))) called at [(null):0]
when creating a block pointing to default vb blocks will work...
update: db tech blocks now working
still not working:
also members can't post replies to threads.....new threads can be created but replies to threads can't....an issue with newpost.php?
CBDC6B1B-BB05-4439-8FEF-F8D47F2D43A4.png~original
the dbtech side blocks are working.....had to re-install the corresponding plugin for them to start working again.....but members are still unable to post replies to threads....
Ahhhhh....that's what was missing from the plugin list....don't remember seeing it now that I recall...I reinstalled all other plugins 1 by 1 and nothing.
Thanks again...
