Question Question on mobile regarding collapsed posts...
ae1360
Just a easy question but maybe not an easy solution: I know it isn't exactly possible to have this working on mobile with how it is currently written but is there a way to prevent posts from being shown as collapsed on the mobile? The reason is that on my old setup, collapsed posts were collapsed on the desktop version but were shown fine in the mobile. With this version, it is as if the post wasn't even there.
I'd like to either:
(1) Have the post just be shown
or
(2) Have a 'view post' button available? The 'view post' button built into vBulletin is the same one you guys use, correct? Because I think that one does work on mobile?
Either way, any insight would be helpful.
The reason why the post is invisible on the Mobile Style is because APTL will override the postbit template with a custom version, which does not exist on the mobile style.
You may have luck creating your own version of the dbtech_thanks_postbit_downranked template in the mobile style. You may be able to simply copy the default postbit template if you'd rather have the post shown.
