Question Post tabs in 4.2x Duplicate issues cant find in postbit
Website
http://qldcichlid.com/forum.php
Forum version
vBulletin 4.2.x
FIIK
Hi guys,
I having the above issue.
The Read me States:
You will need to remove any vBulletin template code from postbit(_legacy)
that you intend to use with Postbit Tabs, otherwise it will display multiple
times.
Would like guide to doing this please.
Regards Luke
Belazor
Staff member
Owner
Developer
On a unmodified template, find:
HTML:
				<dl class="userinfo_extra">
					<vb:if condition="$post['joindate']"><dt>{vb:rawphrase join_date}</dt> <dd>{vb:raw post.joindate}</dd></vb:if>
					<vb:if condition="$post['field2']"><dt>{vb:rawphrase location_perm}</dt> <dd>{vb:raw post.field2}</dd></vb:if>
					<vb:if condition="$post['age']"><dt>{vb:rawphrase age}</dt> <dd>{vb:raw post.age}</dd></vb:if>
					<dt>{vb:rawphrase posts}</dt> <dd>{vb:raw post.posts}</dd>
					{vb:raw template_hook.postbit_userinfo_right_after_posts}
				</dl>
Replace with
HTML:
				</dl>
Find and remove:
HTML:
				<vb:if condition="$show['infraction'] OR $show['reppower']">
				<dl class="user_rep">
					<vb:if condition="$show['infraction']">
					<dt>{vb:rawphrase infractions}</dt>
					<dd>{vb:raw post.warnings}/{vb:raw post.infractions} ({vb:raw post.ipoints})</dd>
					</vb:if>
					<vb:if condition="$show['reputation']">
						<vb:if condition="$show['reppower']">
					<dt>{vb:rawphrase reppower}</dt>
					<dd id="reppower_{vb:raw post.postid}_{vb:raw post.userid}">{vb:raw post.reppower}</dd>
						</vb:if>
					</vb:if>
				</dl>
				</vb:if>
FIIK
Hi again guys,
I did as you suggested above, the issue im now faced with is;
How do I get the member information into a postbit ??
I have all you products set ok, but lost the standard Post's / Location / Join Date info
Thanks again guys
Luke.
#4
Add a view and put this into it:
Postbit Tabs
