Testeren
after updating vbulletin I experience some errors. I contacted vbulletin staff and they send me back to you.
The error that I get is this:
Warning: Assigning the return value of new by reference is deprecated in …./showthread.php(2406) : eval()'d code on line 27
It is not constantly there, but happens every now and then when I click a thread or a section.
Besides this mod, I also run your thanks mod, but I don't know which mod is casing this?
Can you help me with how to fix this problem?
Can you please post the contents of all plugins running on showthread_complete?
Copy/paste the contents of the "PHP Code" field inside
 tags here, and I'll tell you which plugin is at fault and how to fix it :)
Make sure ant DBTech products you are running , re download and upload the newest files, there was a release to ensure PHP 5.4 errors were fixed, 30+ Products Hotfixed for vB 4.2.2 / PHP 5.4
Yes I upgraded all products along with the forum software yesterday so it should be the latest version I have :)
 tags here, and I'll tell you which plugin is at fault and how to fix it :)[/QUOTE]
Can you explain a bit more where to find what? I am not very experienced (or english) :o
It may be easier if you PM me with an AdminCP account, that way I can fix it directly on your site :)
To be clear, the issue is not in any DBTech products (the error message tells me that), but I can still fix it for you since it shouldn't take very long :)
Really? Because Lynne from VBulletin staff wrote me (twice) that the error comes from there.
I will send you a pm right away.
The issue was the Display Event Details on Thread Page - BBR plugin. I have corrected it on your site.
Not this time, but last time there was a prob with a mod, you did. And I followed the same steps and reuploaded the file requested. As I did again now.
Theres one last pm to you regarding a purchase..
Legacy Advanced User Tagging
