Question PHP-Code for Sideblock?
limits
hello,
i have problems to show the spotlight in the sideblock. on vbulletin.org i found a screenshot with php-code in the block editing options
after my installation the field is empty and text is selected. have i missed something or installed it wrong?
or could you please post the code to insert here?
best regards
Ozzy47
Former Developer
Code for the Content Field:
global $vbulletin, $vbphrase;
	if (($vbulletin->options['dbtech_spotlight_location'] == 3) && $vbulletin->options['dbtech_spotlight_enabled'])
		require_once(DIR . '/dbtech/spotlight/core/class_fetchuser.php');
		$spot_user = new FetchUserInfo($vbulletin);
		$spot_userdata = $spot_user->return_spot_user_info();
		return $spot_userdata;
Code for the Template to Use Field:
dbtech_spotlight_userinfo_sideblock
Let me know if it works then.
User Spotlight
