Bug Overdue purchase
Website
https://notdrink.ru
Product version
6.1.0
Forum version
XenForo 2.1.x
NotDrink
If the item is active, it is removed from the inventory after its expiration. If the item is not active, it remains in your inventory even if it has expired. It makes no sense to keep expired items, well, if only to make a meaningless gift.
Why is it done?
Fillip H.
Staff member
Owner
Developer
Whether an item is active or not shouldn’t affect whether it’s auto-discarded after expiry.
I will change this ticket to a Bug and look into it for the next version. Thanks!
Fillip H.
Staff member
Owner
Developer
Upon investigation, the reason why the expiry handler was limited to only active items is the fact that not every item is necessarily set to be discarded upon expiry.
Rather than dismiss this report I have changed it so the expired purchases code will select the item for expiry if it's active OR the item settings are set to discard upon expiry.
In other words, as of the next version, deactivated items that are set to be discarded upon expiry will be discarded.
DragonByte Shop
XenForo 1.5.3+ XenForo 2.0.x XenForo 2.1.x
