They do, just not necessarily on newer versions of vB5.Crap, well they shouldnt be here then. I didnt know none of them work without your support involved.
The issues have now been taken care of on your forum.
There was an incompatibility with the horizontal postbit display style you're using (vs. the "legacy" style we're using here on this forum). I have made changes to the mod that corrects this for all display styles.
No, they shouldn't. The buttons are not clickable (they have a special CSS class that indicates they are disabled), but the button display is mandatory in order to provide the pop-out bubble that lists the number of users that have clicked the buttons.Users can see the thank buttons within their own posts, these should be hidden
If you look at this page: Advanced Post Thanks / Like (vB5) - DragonByte Tech | vBulletin Mods & Addons you will see that "Profile" is listed under "Missing Features". This is not a bug, vBulletin 5 is missing the required template hooks in order to implement profile stats. This is a known issue that is scheduled to be fixed (or has recently been fixed) - I reported the issue in the vBulletin JIRA Issue Tracker myselfNo profile stats
This appears to be a bug in vB5 when disabling a product. I have rebuilt the bitfields and the settings appear correctly now.
