Bug IP whitelisting no longer taking effect
Website
http://www.ng-gaming.net/forums
Product version
3.3.0
Forum version
vBulletin 4.2.x
#1
Ever since we upgraded to PHP 7, the IP whitelist function no longer works, in that anyone can access the AdminCP regardless of if their IP is actually whitelisted or not. I have not seen any errors listed in the error log relating to this.
Belazor
Staff member
Owner
Developer
The only way this could happen is if another system like CloudFlare is messing with the REMOTE_ADDR server variable. Can you please double check you have not enabled CloudFlare, or any new settings within CloudFlare, recently?
#3
We've always had CloudFlare's CDN enabled - I would think this would prevent logging into the AdminCP if it was reporting a different IP though, no?
There have been some settings modified, but nothing that would effect the REMOTE_ADDR variable I don't believe. I did do a quick test to ensure that it was reporting the correct IP in the variable however.
Belazor
Staff member
Owner
Developer
Assuming you don't have the "Exclude Super Administrators" option enabled and only tested it with your own Super Administrator account, can you let me know the exact steps you took to test this?
In other words, did you simply try to have them visit the AdminCP, or did you also have them try to login to the AdminCP?
#7
I did disable the 'exclude Super Administrator' option, but even with or without it enabled it was having no effect regardless of if someone is a Super Admin (we have ~50 people with Forum Admin; I don't necessarily agree with that number but I digress...)
It doesn't prevent them from accessing or logging into the AdminCP. I did test this myself by attempting to connect via a VPS that isn't whitelisted.
Belazor
Staff member
Owner
Developer
In that case, have you tried disabling all other modifications? It sounds like you have a mod conflict.
Company Information
Staff member
Company Info
#10
Hello Devin Lee Clark,
Belazor
Staff member
Owner
Developer
Belazor
Staff member
Owner
Developer
Sorry, I am massively swamped with contractual obligations so I haven't been able to address this yet. I've not forgotten, and I'll get to it as soon as I can.
Sorry for the delay :(
Belazor
Staff member
Owner
Developer
An issue wherein no code in one of the Global Initialisation plugins wasn't being executed at all. That check had changed in my local copy which is why I couldn't replicate it at first.
Company Information
Staff member
Company Info
#18
vBSecurity
