Legacy Input vbsignature screen into vbshop?
Replicators
COuld there be anyway to just move the option from wthin the vbsignatures menu and put them in vbshop instead, i really don;t need 2 shop areas and it would look more organized if it was in vbdhops since the design is very similar.
We'll take it into consideration for future versions :)
It may be quite tricky considering the Preview feature is unique to vBSignatures, and you'd have to go into vBSignatures to configure the completed signature regardless.
I guess to achieve this, both mods would need to be worked out to fit this feature. That is kind of what i like about dbtech is you guy's do seem to work your mod's according to other ones. I just really don't like the idea of my forum having two different shops, even though they both do different thing's, i do think you should use vbshop optionally as a central hub for any other mod though, but of course not required., like you do with vbcredits.
4K
Legacy vBSignatures
