Hi,
is there a simple way to import existing geo data (lat/lon) rather than have the IP's geolocation ?
I have all my users' lat/lon which I'd like to use. Guess I have to deactivate the cron then too.
We hope your ticket regarding Member Map has been addressed to your satisfaction. This ticket has now been closed.
I imported the GPS Data and set the dbtech_membermap_scan=1, which worked well.
Now most users are shown at their location, however some are not shown others cannot move their Icon for the location
I did check, all OK no success.
What I found is an "e" in some GPS data, like 4.764910136773585e15
When I set lat, lng, scan=0 and do start the cron data is updated correctly.
However, after a while the "e" is back 4.764910136773585e15 in the DB
Thnaks. I will check with my hosting guy, but can you please confirm if your Software can cope with this "e" or if this might cause errors? At least with my user I can tell, since the "e" is there my Icon is gone...
checked with my hosting support, they don't have an idea why this "e" occurs. Seems to be a problem with my degrading VB software... Will drop VB and go to XenForo sooner than planned...
