Question How to Purchase Items?
Senkusha
I must be blind. I added some items, ran the Cron to refill the stock, went to the Shop, clicked on something, and I don't see any link, button, voodoo to purchase the item.
Check the configuration to ensure there is actually stock. You can just set the stock manually, ensure both min and max stock is set.
I figured out the problem! I needed to set the permissions for Shop. Probably a bunch of other permissions I need to look at too.
Cheers!
Hello @Senkusha,
Hello @Senkusha,
DragonByte Shop
5.00 star(s) 3 ratings
