Bug Error when order "mark as shipped"
wlanthermo
This error occurs when an order should be marked as shipped. In the order log.
After that, the order can not be re-branded as shipped.
This will be resolved in the next version, and I've patched the existing version. If you re-download v1.3.4.1 and re-upload the files, it'll be fixed for you.
Thank you. Error is fixed.
But there seems to be another error in the sent e-mail.
The variable {boardTitle} is not replaced correctly. In the subject of the email (see the mark).
I'll fix that in the next version, thanks. Meanwhile, you can use {board_title} instead as that is the correct replacement.
Hello @wlanthermo,
4.83 star(s) 6 ratings
