Optimus
Member
This may seem like a weird question, but I was wondering if it were possible to remove the error message given when links are turned off in PMs. I wanted the PM to still go through as if the PM wasn't blocked from being sent (when in actuality, it was), complete with the user being redirected back to the inbox completely oblivious. Which template (or php file) would I need to edit in order to remove the current error: "Read the below message to see what went wrong with your submission Sorry member, you are not allowed to post links in PM's messages. Click button to go back to previous page." and instead insert the standard "your Pm was successfully sent" message.
This kind of modification is beyond what we normally support, so what I would suggest is search the Phrase Manager for the blocked PM text, find the phrase "varname" then do a search in all files for references to that varname. You can then add the redirect as needed :)
Legacy vBSuper PM's
