A new update is available for DragonByte eCommerce by DragonByte Technologies.
DragonByte eCommerce 1.1.4
Update highlights
This release contains a few new features as well as various tweaks and fixes.
There's a new setting that allows you to toggle the "Income" block displayed on the AdminCP home page, should you wish to disable it.
The "Downloads" page under the "Digital products" header can now be searched in a similar way to how the various logs can be searched, with the ability to filter by release date range, download state (visible, deleted, moderated) and of course, the product.
Lastly on the list of things worth mentioning, the product pricing row has been fixed after XF 2.0.10 rejigged some CSS that made it not render properly.
Complete Change Log
Feature: The "Income" block in the AdminCP can now be disabled via a new setting
Feature: Downloads are now searchable in the AdminCP, similar to log pages
Change: When a staff member downloads a licensed product from another user's license list, the staff member will no longer auto-watch the product
Change: Breadcrumbs have been added for the various "delete" overlays, making navigation easier if these overlays are instead opened in a new tab
Change: The "Add license" button now uses the "call to action" colour to distinguish it from other buttons on that page
Fix: Fixed a CSS issue with the product pricing row after the XF 2.0.10 update
Read more about this product...
Update highlights
Complete Change Log
