A new update is available for DragonByte Donate by DragonByte Technologies.
DragonByte Donate 3.2.2
Update highlights
This version refines the navbar integration by adding FontAwesome icons for menu entries when positioned in the right-side menu, as well as adding the ability to disable the text. Lastly, the HTML has been updated to better blend in with other right-side navbar items.
This has been tested on a limited number of custom skins. If you encounter any problems with the right-side menu after installing this update, please report it to the developer of your custom skin and ask them to get in touch with us to notify us of any changes we need to make.
Complete Change Log
Feature: Added FontAwesome icons for right-side menu entries
Feature: Added ability to disable the navbar text for right-side menu entries
Change: Updated the style of right-side menu entries to better fit into the surrounding entries
Read more about this product...
Update highlights
Complete Change Log
