A new update is available for DragonByte Credits by DragonByte Technologies.
DragonByte Credits 5.1.0rc3
Update highlights
!!! DO NOT INSTALL THIS VERSION IF YOU ARE RUNNING DRAGONBYTE SHOP v6.0.x !!!
This version contains bug fixes and feature improvements.
Currency formatting is now applied more universally, so if your site is using very large currency amounts you will no longer have to keep track of digits by tracing your finger over the screen
The "Richest user" widget was previously not respecting the "limit" setting in the widget config, this has now been addressed.
The template modification for inserting our
The "Frequency" setting in events was only partially working in v5.1; setting it to a value of f.ex. 30 would actually require 31 events to be skipped in order for the 32nd event to successfully trigger. This now correctly requires only 29 events to be skipped in order for the 30th to trigger, as you would expect.
Lastly, we've added an
If you want the full details on the v5.1.0 release, you can check it out here: https://www.dragonbyte-tech.com/store/dragonbyte-credits.339/release/1713/
Complete Change Log
Change: Added install-upgrade.json file
Change: Currency formatting is now applied more universally
Fix: The editor.js file is now no longer loaded even on pages where the editor isn't loaded
Fix: The "Richest user" widget now respects the limits in the widget settings
Fix: The "Frequency" setting for events would cause too many events to be skipped
Read more about this product...
Update highlights
editor.js
file used for the pop-up Charge button will now only load when the rest of the editor's JS code loads.The "Frequency" setting in events was only partially working in v5.1; setting it to a value of f.ex. 30 would actually require 31 events to be skipped in order for the 32nd event to successfully trigger. This now correctly requires only 29 events to be skipped in order for the 30th to trigger, as you would expect.
file in preparation for compatibility with the [TH] Install & Upgrade add-on.If you want the full details on the v5.1.0 release, you can check it out here: https://www.dragonbyte-tech.com/store/dragonbyte-credits.339/release/1713/
Complete Change Log
