forums55
1). Every time someone is quoted they receive a Private Message saying "You Have Been Quoted!" and also they receive the Notification that they have been quoted. The notification is sufficient, I want to disable users getting PM when being quoted. How can it be done?
2). I'd like to continue using "Mentions" by @ tag, but I'd like to remove the "Mentioned:" text in the Users forum display. How can this be done?
1. This mod does not have Private Message notifications. Are you talking about emails? If so, you can disable it via the "Disabled Emails" function in the vBulletin Options for this mod.
2. Configure the "(Pro) Postbit Integration" setting in the vBulletin Options for this mod.
When someone is quoted, it receives an automatic PM message from the user that quoted, saying:
Userquoted You Have Been Quoted!
Hey there Userquoted,
user_x has just quoted you in a post. user_x's quotes of you are:
Quote Originally Posted by Userquoted
Test
To view the post where user_x quoted you, click here.
The PM comes from the user that quotes and is sent to the quoted user.
That is unrelated to this mod. The text you are showing me does not exist in any of our products.
Feel free to search for "You Have Been Quoted!" or "Hey there" in the Phrase Manager, and see that the "varname" of the phrase does not contain dbtech_usertag_ :)
Yes, you are correct, it seems was from the vBsuper PM (by dragonbyte). Thanks for your support, this thread can be closed as its solved.
Legacy Advanced User Tagging
