matthardy
Hi,
something is wrong with the pagination on "DBTech - Post Thanks > Search". First page displays correctly, but when I hit on Next Page or Last Page button I get an empty frame.
The search is not a very importat feature, but I'm afraid something else might be broken. No errors are displayed even though vBulletin debug mode is enabled and php also displays errors.
Here is what I get: View image: thanks
I've upgraded my vBulletin to the latest version and also installed new DBTech - Post Thanks plugin. There was no problems while upgrading.
Upgrade instructions in readme files are not very clear. documentation.html does not work localy (no matter what browser). So eventualy I found online documentation.
You should have step by step instructions how to upgrade.
Right now I'd like to know answer to this question: How to make sure that upgrade was successfull?
My forum is installed locally so I can't give you any access to it.
Hi,
Confirmed, will fix for Beta 3 :)
1. Upload all files from the "upload" folder to your forums directory.
2. CHMOD the following folders to 0777
/dbtech/thanks/vbactivity_type
3. Import the product-dbtech_thanks.xml file from the "XML" folder at AdminCP ->
Plugins & Products -> Manage Products -> Add/Import Product
4. Configure your Usergroup settings by clicking "Manage Buttons" under
"DBTech - Post Thanks" in your AdminCP navigation menu, then
editing each button and setting your usergroup permissions from there.
That seems pretty clear to me, but then again I am famous for not being able to put myself in others shoes and see things from the perspective of a non-coder :D
If you could point out which part of that is unclear I'll correct it :)
Seems to work fine for me, on Google Chrome :)
See the quoted bit above :)
Were there any error messages during or after upgrade? If not, then it was successful :)
Thanks for quick response. You might be right about upgrade instructions, after all I've upgraded successfully :)
Speaking of documentation.html, it does not work correctly. Opening external links using javascript is silently blocked by every browser I've tried (even IE6 on winxp gave me permission denied). You should include a complete help.
Unfortunately it's not feasible for us to include a complete documentation in the zip due to the sheer size of the full documentation, plus the fact that it would make it a lot more difficult to maintain updates to it :(
