DBTech Navbar custom forum link Error
CoZmicShReddeR
Used Navbar to go to a custom forum linked with the "Minecraft tab" for the CozWorld Minecraft forums
The tab link showed
http://www.cozworld.com/f220/
Error Results are:
Fatal error: Using $this when not in object context in /home/content/47/9320747/html/dbtech/dbseo/hooks/xml_print_output.php on line 20
It would seem any link created guided to the website forums in the navbar has the same error:
I uploaded a fixed XML file, if you re-download the product and re-import the XML file it should be working now :)
Ok good that worked.... And it wasn't just the nav link it was any link to a forums post but guess you figured it out... Seems good now and will keep flipping through my site to see if there are anymore issues...
I will keep an eye on my analytical data as well to see if I am getting picked up by more search queries.
