Question DB Seo problem redirect link
boldherri
Member
Hello, i have always problem on mod Dragonbytes:RpS_sad:
i have problem when i open links forum appear this message
Not Found
The requested URL /reviews/review/ was not found on this server.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.29 (Unix) mod_ssl/2.2.29 OpenSSL/1.0.1e-fips mod_bwlimited/1.4 Server at xboxitaly.it Port 80
if i disable the product db seo i no have problem if enable DB seo i have this problem.
I have tried both approaches, and there is always the problem
this is my htaccess
<IfModule mod_rewrite.c>
RewriteEngine on
# Set to vbulletin directory
RewriteBase /
# Retrieve gamedata requests and send to new dbtech locations
RewriteRule ^arcade/gamedata/(.*) dbtech/vbarcade/media/$1 [L]
# Retrieve crossdomain requests and send to new dbtech location
RewriteRule ^crossdomain\.xml dbtech/vbarcade/crossdomain.xml [L]
# Send hardcoded legacy scores to arcade instead
RewriteCond %{REQUEST_URI} newscore\.php [OR]
RewriteCond %{REQUEST_URI} viewgame\.php
RewriteRule .* arcade.php?sendscore=legacy [L,QSA]
RewriteCond %{QUERY_STRING} act=arcadelib [OR]
RewriteCond %{QUERY_STRING} act=Arcade
# Reroute v3arcade liveinstaller
RewriteCond %{QUERY_STRING} do=liveinstall
RewriteCond %{REQUEST_URI} v3arcade_admin\.php
# If you renamed your admincp directory, change it here
RewriteRule .* %{DOCUMENT_ROOT}/admincp/arcade_admin.php?%{QUERY_STRING}&do=review&import=browse&system=v3a [L,R=301]
</IfModule>
RewriteEngine on
# RewriteBase /forum/
# Options -MultiViews
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
# Forum
RewriteRule ^threads/.* showthread.php [QSA]
RewriteRule ^forums/.* forumdisplay.php [QSA]
RewriteRule ^members/.* member.php [QSA]
RewriteRule ^blogs/.* blog.php [QSA]
RewriteRule ^entries/.* entry.php [QSA]
# MVC
RewriteRule ^(?:(.*?)(?:/|$))(.*|$)$ $1.php?r=$2 [QSA]
# Check MVC result
RewriteRule ^(.*)$ - [NC,L]
RewriteRule ^(.*)$ - [R=404,L]
RewriteEngine On
# RewriteBase /
</IfModule>
you can help me solve this problem please?
You are attempting to use both vB4's rewrite rules AND DBSEO's rewrite rules. This does not work.
Change your .htaccess to this:
	RewriteEngine on
	RewriteBase /
	# Forum
</IfModule>
Set the vB Friendly URLs to Off, set Canonical URLs to Off, set Guest Canonical URLs to Off.
Hi [MENTIONS]Fillip H.[/MENTIONS]
I ran your advice and now does not give me error, when i open the link always brings me back page vBCms Comments
for me it is very important that the db seo work correctly in forum.
EDIT:
only now I've seen this problem, in my topic with pictures and videos there are not in the thread
RI-EDIT:
I have noticed one thing, if i login as a user is all ok, the connections link are correct, if I login as admin or moderator the forum is all unpacked, the connections of the link to the forum are incorrect.
in more colors nicknames groups moderastore and super moderator have changed.
unregistered users see everything properly and not registered not work link.
Sorry, I don't understand any of that.
If you are having a problem that only affects certain usergroups, you may have a mod conflict. You should try disabling all other modifications and try again.
I'm sorry for my english
If options in friendly url i cue the apply URL canons for members on no unregistered users the links are correct, while all other groups the links are incorrect.
The issue was that the vBCMS Comments forum was not excluded from the vSA statistics modification. I have applied this, and the thread displays are now identical for guests and members.
Hi Fillip H., i've seen now work well, now your support is impeccable.
you've been very good.
Thank you so much for your support:)
Tags Tags
db error
