SetEnv TZ Europe/Berlin
# Comment the following line (add '#' at the beginning)
# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
#RewriteBase /
# Options -MultiViews
RewriteCond %{QUERY_STRING} !dbseourl=
RewriteRule ^(.*\.php)$ dbseo.php?dbseourl=$1 [L,QSA]
RewriteCond %{HTTP_USER_AGENT} (Boardreader|boardreader) [NC]
RewriteRule ^.*
Boardreader - Forum Search Engine [R=permanent,L]
RewriteCond %{HTTP_REFERER} ^
http://(.+\.)?omega-freak\.de/ [NC]
RewriteRule .*\.(jpg|jpeg|gif|png|bmp|swf)$
https://www.opel-problemforum.de/klau.jpg [R,NC]
