Legacy Allow usergroups to turn off button notifs from forum sections of their choosing
pwnage
Allow usergroups to turn off button notifs from forum sections of their choosing -UPD
Advanced Button Notification Settings- Located in the UserCP;
- Which notification setting do you want to enable/disable?
Like [tick/untick] - Dislike [tick/untick] - Thank [tick/untick] - Custom Buttons [tick/untick]
Note: By default, all should be ticked.
- Which [Button] & ForumID do you want to notifications disabled from all users? [Big Empty Box - Example]
Key: Button|ForumIDs;
Example: Like|1,3,6; Dislike|49,16,23; Thank|8;
- How much do you want to limit [Button] notifications on a per forum basis? [Big Empty Box - Example]
Note: Separate each condition with a semicolon ;
Key: Like,ForumID|Friends; ForumID|Contacts; ForumID|ExcludeUsergroup:[Insert Number]; ForumID|User:[Insert Number]; ForumID|ExcludeUser:[Insert Number];
Example:
Like,2|Friends; 2|ExcludeUsergroup:1,8,4; 2|User:1,34,5,328; 2|ExcludeUser:2,3,56,142;
Thank,4|Friends; 4|Contacts; 4|ExcludeUsergroup:3,1,2; 4|User:2,21,78,428; 4|ExcludeUser:4,7,32,193;
Explanation! -> Please click, for a more in-depth explanation of the key.
^This might not be the best way to code/arrange it, if you know a simpler way, you can do that.
Note: All these settings only appears, if the usergroup is allowed from AdminCP (as seen below)
Somewhere in the Admin CP (for this mod);
- Which usergroups do you want to allow to view the 'Advanced Button Notification Settings' to appear in their UserCP? [Multiple-Selection Menu - Select Usergroups, use CTRL to click & highlight more than one]
- Which usergroups are immune from having their Buttons notifications from being disabled? [Multiple-Selection Menu - Select Usergroups, use CTRL to click & highlight more than one]
- Which usergroups can see the 'On a per thread level' button notification settings? [Multiple-Selection Menu - Select Usergroups, use CTRL to click & highlight more than one]
On a per thread level:
- Which [Button(s)] notifications obeys UserCP settings for notifications?
User selects which buttons via Multiple-Selection Menu. They can highlight multiple buttons (ctrl + click to select more than one).
- Which [Button(s)] notifications doesn't obey UserCP settings and allows all [Button(s)] on this thread to send you notifications?
- Which [Button(s)] notifications doesn't obey UserCP settings and mutes all [Button(s)] from sending you any notifications on this thread?
Note:
http://www.dragonbyte-tech.com/f51/...notifications-certain-forums-18708/#post95215
I made a similar request for the user tagging mod.
