RollaJedi
Hello
I use vbexperience and you earn their points. I'm going to purchase the pro version of triple triad from you. Can I use their points as money for triple triad? If so, i need to know what to put in the field for their money. thanks!
Hi Rolla,
I'm not sure what field vBExperience use to store there points, you'd have to ask the developer :) If the field is numeric it can be used in TT just fine.
Looks like he'd require hooks in order to get it to work so it wouldn't damage his rebuild functionality - it won't support the integration TT has since that expects a field which it can simply add or take money away from. Doing so without the hooks would probably break vBExperience counters so I wouldn't recommend it personally.
is there any kind of bundle for gettting the vbactivty and triple triad pro and support forever? if there was, i'd probably do it
Our bulk purchases give you discounts when you spend money on 2 or more products which means you can mix and match and make your own bundles :)
Legacy Triple Triad
