Bug Short answer quizes not being scored correctly.
kcwayland
So we are creating Quizes with short answer and then judging them, but each time the score comes out to 0% on the review quiz side. Any idea why that might be?
3/3 would be 100%, yes?
Ok, so I think I see the issue. It calculates correctly if I go into AdminCp and tell it to recalculate the high scores. Do I have to do that manually, or how often will it do it on its own?
Sorry, it's a bug in the code.
I'll fix it in the next release. If you want to fix it yourself manually for now
Open dbtech/vbquiz/actions/quizcomm.php
About line 714 you'll find
            $vbulletin->db->query_write("
                UPDATE " . TABLE_PREFIX . "dbtech_vbquiz_taken
                SET
                    percent_result_id    = " . intval($percent_total) . ",
                    final_score            = " . intval($final_score) . ",
                    possible_score        = " . intval($possible_score) . ",
                    judged                = '1',
                    judgerid            = " . intval($vbulletin->userinfo['userid']) . "
                WHERE
                    taken_id            = " . intval($subid)
Change it to
                SET
                    final_result_text    = '" . intval($percent_total) . "%',
                    judged                = '1',
                WHERE
After that, when you judge a quiz it should display correctly.
                SET
                    judged                = '1',
                WHERE
Change it to
                SET
                    judged                = '1',
                WHERE
Awesome! I'll try it out. Thanks!
Legacy vBQuiz
