Drahnier
the scoring system doesn't seem to work properly, I have taken only games that said they supported Local scoring and yet none of them seem to work
most games return a score of 0, the first person to play them holding the trophy
one game(Bomber Fruit) does output a time but the high score place is simply held by the most recent to play it seems
Here are the current reasons why scores might not be submitting on your site:
  • The permissions for you and that game have not been set to Score (as opposed to Play or Record)
  • The game has been set to not accept local scoring
  • The game has been set to the wrong scoring system
  • Your game session has not submitted the score
  • Your .htaccess file has not been altered correctly (usually indicated by errors during product import)
  • Your arcade is set to archive your non-best scores, and that was not your best score
  • Your site is behind a server password prompt
  • Mochi: you do not have your publisher id or secret filled in
  • Mochi: you are running the arcade from localhost
ALMOST ALWAYS is it the first bullet, check that first, the next two are USUALLY set automatically, MOST games will have a well-informed score submission time (though I've seen games that send without telling you, and some that don't actually send despite claiming it), the fifth bullet will usually throw installer errors/messages, and the sixth bullet should at least show some scores from somewhere being saved. Usually games can't post through your password prompt, and especially not if you are using mochi, which sends scores from their remote servers without your forum session.
Do only specific games, or specific scoring systems, or all games not save scoring for yourself, specific usergroups, or everyone?
Check all that our and report back with your findings. If none of the above works the issue will be troubleshot further
it was this one
didn't know that mattered so much
Question html5 games
Question Arcade Menu
Legacy vBArcade
