Nirjonadda
DBTech - vBActivity > Points Settings > Points For [DBTech] DragonByte Gallery Uploads? Does not found,Where i can change Points For [DBTech] DragonByte Gallery Uploads to Points For Gallery Uploads? Its someting like bug show.
That's not a bug. It's simply the fact that the phrase is too long to fit within that space. You can change the phrase yourself via the Phrase Manager if it bothers you, simply search for that text :)
dbtech_vbactivity_condition_dbgalleryupload and dbtech_vbactivity_condition_perdbgalleryupload :)
vBPhrases might be useful for you in determining phrase names as well :)
where i can turn off Points For [DBTech] DragonByte Gallery Uploads? does not found here DBTech - vBActivity > Points Settings > Points For [DBTech] DragonByte Gallery Uploads?
It looks like there's an issue with its points settings.
Run the following query:
UPDATE dbtech_vbactivity_type SET settings = 15 WHERE typename = 'dbgalleryupload'
Remember to add the table prefix if you use one.
Then use the Repair Cache feature.
Afterwards, it should show up.
UPDATE vbdbtech_vbactivity_type SET settings = 15 WHERE typename = 'dbgalleryupload'
Great, thanks :)
If you would like to leave a review for this modification, you can either visit your Client Area or visit our front page and click [Leave A Review].
Leaving a review helps other users make good purchasing decisions, in addition you will be rewarded with free money to spend on any DBTech products you like!
For more information, click here.
Reviews are placed under moderation when they are first added, once Cosmic's had a chance to read over it and confirm it you'll see it show up :)
Thanks!
Legacy vBActivity & Awards
