Question Installation
Shimei
I am not a coder.... I need help installing this in my Paragon theme. I would like the slider installed so it is right of the logo up top the template. I installed the pro package.... that's as far as I can get.
Thanks,
William
If you access the Instance Manager under the DBTech - vBSlider menu, you should be able to find the settings for manual deployment. If you follow the instructions on that page, you'll have complete control over the position of the slider :)
No luck... I am sorry to request this indepth help. But could someone look into this and get this ready. My site is located here: Reformed Christianity
The slider is activated at this moment and so is the default instance.
Thanks,
William
I think I misread the first post, is the logo in the header template? If so, the slider isn't designed to be displayed there unfortunately :(
I figured it out, the "Latest Threads" had been set to 0. I set it to 5 and it shows up now :)
Hello Shimei,
Legacy vBSlider
