Bug I got the one problem with 1.2.4 pro.
rainyleaves
I tested with 1.2.4 Pro & Lite version.
I got the one problem.
I open the two windows with 1.2.4 wall page.
And I write 'update status'(comment).
There are same 'update status'(comment) automatically appeared with two windows. That's no problem.
And I delete the 'update status'(comment) for first window.
But It doesn't automatically disappeared second window's 'update status'(comment).
I mean Another window's(second windows) same 'update status'(comment) is not disappear when I delete the first window's same 'update status'(comment).
I think you need check the disappear fuctionality(Ajax Refresh) when delete the 'update status'(comment).
I get same problem with Comment.
Sorry my bad English... :)
That's working as intended, it does not delete or update any existing statuses or anything else due to the performance hit this would cause :)
