What skins are you having issues with? I am seeing no problems with multiple navbars on both Swans Home and Swans Away. All subnavs work, and the skin does not look like it does in your screenshot.
Please provide step-by-step instructions for how to replicate your screenshots.
Ok the screenshots provided were the result of a previous fix for a blue pearl skin issue which didn't work, so I reverted things. I am missing the original breadcrumb and my social media icons that should be there under the nav bar. Also if you look at the footer in the second image I supplied then you will see that that should not be like that.
Do you have a screenshot of the things mentioned in your post as they are supposed to look? I'm not familiar with your skin, so I really don't know how it's supposed to look :(
Ok this is how things should look with your mod disabled (should be like this with your mod enabled)
This is how things look with your mod enabled
Hope those help.
Thank you for your help Fillip H. much appreciated, can you advise how you fixed the issue for future reference.
I used a file comparison tool to compare the customisations in the themes to the default vbnavtabs template, and merged customisations as appropriate.
Legacy vBNavTabs
